Actually Brain, i challege you on that thought, the turbo ACTUALLY takes heat out of the exhaust gasses, it needs to do this to generate the power to pump air for the motor, this is why a lot of turboed engines dont need an exhaust, as the heat is what causes the noise from an exhaust, it is the heat cooling that is the noise you hear.
But i do agree that turbos not set up right will cause heat problems elsewhere in the motor.
Nothing wrong with any rotax for that matter
less weight and the best power to weight going.
But i guess for people who dont really need this it is point less to keep bringing this up
You are correct Bones, and you are also correct in saying that turbos not set up can create havoc with increased temps, usually in the bits that dont really need any more heating. I'm also a bit biased re turbos, unless its a 914, or else you are a social flyer, then leave the anchors in the box and get a real engine!!
I had so much trouble with my first engine on this gyro that I nearly gave away flying [factory turboed EA 82] !!! Having said that, I reckon all Diesels should have hair dryers,
I have seen a photo of your exhaust set up Disco and while I'm no techy, the exhaust could be better directed away towards the tip so as to dissipate whatever heat that is being produced.
